Which build is good? I want a build that can do 4k?
https://linustechtips.com/topic/1248848-help-with-pc-build/
4k what? Gaming?
Both of these will not give you a good experience at 4k.
Whats the budget?
https://linustechtips.com/topic/1248848-help-with-pc-build/#findComment-14038250
4K what, gaming? And if so, what sort of games/settings? Also, what's yout budget?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1248848-help-with-pc-build/#findComment-14038252
2 minutes ago, Slottr said:
4k what? Gaming?
Whats the budget?
Yea 4k gaming and the budget is 800 - 1000 and game setting at least medium to high? if 4k isn't possible at that budget then at least 2560x1440 60 fps +.
https://linustechtips.com/topic/1248848-help-with-pc-build/#findComment-14038278
3600 with a 5700 XT. Should run you around 900-1000.
Or wait for a 3070
https://linustechtips.com/topic/1248848-help-with-pc-build/#findComment-14038281
Alternatively you could wait for RDNA2 GPUs - AMD will most likely have something ready at the ~$400 mark, and you'll definitely be getting more for your money then. The reveal is on October 28th, so the release will be sometime in November most likely.
By then Zen 3 CPUs should also be out, so there's that as well.
https://linustechtips.com/topic/1248848-help-with-pc-build/#findComment-14038297
That's a great list.
https://linustechtips.com/topic/1248848-help-with-pc-build/#findComment-14038310
Thanks will look into your list and will look into the new hardware releasing.
https://linustechtips.com/topic/1248848-help-with-pc-build/#findComment-14038341
