PSU Wattage issue for the RTX 3080
Hi,
Since the RTX 3080 was launched, they said that it's recommended PSU wattage is 750w.
but do i really need to get a new psu? since i just built my pc around february 2020, am rocking a Corsair RM650x (80 Gold plus).
My pc specs:
Intel I9 9900K
Msi MPG Z390m gaming edge ac motherboard
Corsair dominator platinum 32gb ram
Noctua Nh-u12A
Samsung evo plus 500gb
Toshiba 2.5" hdd 1tb
Corsair RM650X PSU
I waited on getting a grapics card, because i wanted to get the new RTX 3080 series.
but my question is, Do i really need a 750w psu for the RTX3080? would my 650w be enough?
Please help me out guys.
There's another thread about this in the PSU section:
It's just something to discuss right now, and since not very many people have a 3080 at the moment, it might be worth it to wait a bit, or just to discuss general power supply issues, etc.
Thing is you may actually need even 850W PSU if you're doing OC, but nothing definite right now ...
Tag or quote me so i see your reply
Thanks.
Yeah i think i'll wait on it, until more people get their hands on the 3080 and their experience with a 650w psu + their feedback.
Are you overclocking the cpu?  Do you think you are going to overclock the gpu?  You should upgrade to a 750 or 850 watt power supply.  I heard that Nvidia recommends at least a 750 watt power supply for the RTX 3080.
3080 power draw in the 320(stock)-375w range(GamersNexus), reviews I see for the 9900k say 200(stock)-250w (Tom's Hardware).
So if not OC'ing it should be ok, if OC'ing you probably want to get more power delivery
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
No. i won't be overclocking my cpu or gpu.
Thanks.
Thanks for the tip, your right.
but i'll still wait until more people get their hands on the 3080 and use it with a 650w psu + their feedback.
