try turning off each individual fan through software and see if the issue goes away when you turn off one of them. you could try to repair that fan but personally I would just buy a new one because its not worth the effort. and seeing that you have an ROG GPU you probably agree with me
https://linustechtips.com/topic/1248471-noise-coming-from-pc/#findComment-14035068
Thanks for the quick response. So you think it’s one of the fans?
https://linustechtips.com/topic/1248471-noise-coming-from-pc/#findComment-14035120
  • 4 weeks later...
