Best Monitor below 500 euros?
Cedri
So I am going to buy a new monitor with a budget of 500 euros. I have a rx 5700xt and ryzen 5 3600. I would like a monitor with 1440p and 144hz+. HDR could be nice but is not a must, so is a USB hub. I already picked 2 monitors but idk if they are good? Gigabyte G34WQC and Samsung LC27HG70QQUXEN.
I really like RTINGS' monitor reviews. They have a couple best picks that I trust (though not very complete).
https://www.rtings.com/monitor/reviews/best/by-usage/gaming
https://www.rtings.com/monitor/reviews/best/1440p-144hz
The only downside to their website is you need to pay a premium subscription to see price in their own website (otherwise you have to click through to Amazon, which probably generates them a small amount of revenue)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
If I'd aks you to choose between these two:
Samsung CHG70
ASUS TUF VG27AQ
Which one would you choose?
Edit: Price is basically the same (except for 32 inch model for Samsung)
Samsung CHG70
ASUS TUF VG27AQ
If you care about HDR, I'd go for the CHG70. Otherwise the IPS Panel on the ASUS is better overall.
Computer Specs:
Which one would you choose? Like for gaming and schoolwork.
I'd personally go for the ASUS here.
Computer Specs:
i think the blind recomendation is LG 27GL850-B
I also don't have it, but i ve never realy heard anyone haveing strong arguments against the dislpay, just some about the form factor (plastci and things)
The samsung has better freesync support?
What is the difference between that one and the LG 27GL850?
i m not sure but i think B stand for Black :D
And why wouldn't you pick the Asus or Samsung one?
Well both have it 😛
I haven't heard of significant differences between freesync implementations.
Do keep in mind the review quotes the Samsung as having bad response time at 60Hz (but good at 144)
Computer Specs:
Just now, Energycore said:
Well both have it 😛
ye but I'm going to play at 144hz so does it really matter? Viewing angles also don't really matter to me.
Do you care about HDR?
Computer Specs:
Would be a nice extra but not really necessary because little games support it. I do play Battlefield V, that  game supports it right? Then it  would be nice.
Sounds like the Samsung then (out of these two). It's the one with better picture quality
Computer Specs:
 The Asus one is the best of the three right  (including the lg)? Samsung is only better if I would really need hdr?
There is no "best" monitors objectively. Both are comparably good, and it's about which one suits your particular needs. That's why I asked the questions I did
Computer Specs:
Which one suits me best?
Can't go wrong with the ASUS considering HDR is not a priority. That's what I'd get.
Computer Specs:
And why not the LG? Sorry for bothering you with these useless questions but I really want to get a good one.
I don't have info on the LG.
Computer Specs:
Hardware Unboxed says the lg is best except if you want the special features and better colours that the ASUS has. The response time is way better tho on the lg. I will not use my monitor for watchinig a lot of netflix and yt so I think I am going with the LG?
yes, and they do so so many tests to so many monitors, and that on is a champion on almost every category
