Recommendation for headphones with mic
HeyIAmInfinity
Hi everyone, i'm looking for an headphone with an integrated mic, at what i consider a middle budget 200-500 usd.
Cheaper would be fine if it has a good build quality.
I don't need it to have a high quality mic (singing, studio) but something with good quality for voip.
It should not be wireless, unless it has 4 weeks battery life (and i doubt one exist), metal chassis would be better that plastic and sturdy enough i can drop it and won't break with a long cable (more than 1 meter).
USB A or normal audio jack, not apple or usb C unless it comes with an adapter.
Thanks.
Imo your best bet is a headphone + modmic combo. Even combos like the Beyerdynamic DT 990 (140$) and a Antlion Audio ModMic (60$) will be worlds better than even 300$+ headsets.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
4 hours ago, HenrySalayne said:
MMX-300. It's basically a DT-770 with a microphone.
But 100 dollars more expensive.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
3 minutes ago, HenrySalayne said:
Yes, because there is a good microphone included. You will certainly pay the same for an equally good external microphone and the OP asked for a headset.
I mean. The modmic 4 uni is not worse really. Except you get 2 cables.
AKG P420 Mic
Other peripherals
