Hey guys, i recently got a 1500Va eaton ups
I was actually excited for that one because i really need it, and from the moment i plugged it in, the fans started running seemingly at full speed, and i didnt even connect it to my pc yet.
Right now my pc is on and it is still very very loud. Ive had a super quiet ups up until now and when i checked the db on the site it showed only a difference of about 5 db.
I only now notice that my previous one didnt have a fan at all..
I guess i fucked up, but i paid good money for this.. Is there any way to make it stop turn the fans at least when the pc is off or the pc is on low load? It would mean alot.. It makes me crazy
The model is eaton 5e 1500i with usb
https://linustechtips.com/topic/1247151-eaton-ups/
Contact Eaton's support? Or check the manual?
https://linustechtips.com/topic/1247151-eaton-ups/#findComment-14023819
  • 4 years later...
On 9/15/2020 at 5:32 PM, lior1111 said:
Manual says it takes 8 hours to be fully charged. Can it be the reason it is loud right now as i just plugged it in? Is it possible it will go quiet once charged?
Hi @lior1111 , i know that this is an old thread, but i'm having the same issue as you, did you fix it ? i just got a eaton 5e 1500i ups, and when i plugged it to the wall the fan stated going crazy fast, with a lot of noise, it's like i have an airfyer in my room. it's been like this for 4 hours now. will it shut off ? or this is a problem with the PSU ? thank you!
https://linustechtips.com/topic/1247151-eaton-ups/#findComment-16717698
