i bought the sound blaster g6 2 days ago, and i was using it with the hyperx cloud flight. i have turned the setting to low, for low ohm headphones, but its just too loud for me i have to keep the volume at 4% at all times. i was considering a audio technica M50x, would that solve the problem? and will the sound quality improve from my cloud flight?
https://linustechtips.com/topic/1247031-sound-blasterx-g6/
The m50x are really bad for gaming. Small soundstage, and just a bad sound signature. If you have an amp. Like the G6 just buy a pair of like DT 770 pro 80ohm or DT 990 pro 250ohm.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1247031-sound-blasterx-g6/#findComment-14023593
1413753942_Skrmklipp.PNG.f0bccd436191cecadd14f8fe8239b968.PNG There is an option called smart volume. Turn that down also.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1247031-sound-blasterx-g6/#findComment-14023596
Thanks for the recommendations, imma look into those
https://linustechtips.com/topic/1247031-sound-blasterx-g6/#findComment-14025203
