Best truly wireless earbuds?
WhalesGawd
I'm in the market for some Bluetooth earbuds, preferably truly wireless. My budget is around 200$. The features id like are ok for exercising (doesnt have to be amazing), maybe water proof, would love for it to be able to wireless charge but definitely want it to be at least type c charging. Just looking for suggestions. Thanks!
Yeet
I don't think there's really a "best" wireless earbud. You have to pick the features and design you want, and then go from there.
Based on what you've said, I'd probably say Galaxy Buds+.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I was looking into those
Yeet
1 hour ago, rice guru said:
what kind of music do you listen to?
Honestly alot of different stuff. But kinda more pop sounding some rap and a little rock. And also podcasts
Yeet
If you don't mind spending a little more (depending on pricing where you are) I'd look pretty hard at the Jabra Elite 75t.
for that I like the jabra elite 65t. AKG N400's, and if you cant stretch the budget a bit the sony Xm3's
I'm checking some out myself.
In my opinion it really depends on what you want and need.
Like for sport you'd need to account water resistance and hope they don't slip from sweat. In general that shouldn't be a problem.
Do you want ANC or PNC or none?
What kind of music?
Are voice-calls or podcasts important etc?
Do you wanna wear them for extended periods of time.
What phone do you use?
Personal preference.
etc.
These are all things to consider. When you got that completely sorted out you should focus on those that are ideal for your goals.
For example: If you really need noise cancelation, the Sony XM3's are the ones to go. Unfortunately these are a bit more than 200.
If you want to wear some long and comfortable that fit with a daily lifestyle go for Samsung galaxy buds live. These should be around 170 to 180.
They would be ideal for sporting as well. They are not completely closed off so you'll be able to hear some of your surrounding without compromising sound/music quality.
