Hello
I have an RX 570, and I recently found out about supersampling, or virtual super resolution in the AMD Driver Software.
I turned that on, and I can go past my native resolution, which is 1440x900. I want to run 1920x1080.
When I select that resolution, it just doesn't work. The image just gets blurry and it's moved to the side, like without it even being on.
I tested it on GTA 5 and Warframe so far, and it didn't work in neither.
Did I do something wrong or is there something else I have to do?
https://linustechtips.com/topic/1246774-i-need-help-with-supersampling/
I'd recommend against using it in the first place. It basically does the same thing as ant-aliasing, but it does it worse, and it has a bigger performance hit.
You are much better off using a higher anti-aliasing setting.
Edit:
The only valid use case I can think of, is for a game that does not support standard anti-aliasing techniques.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
are you sure your monitor resolution 1440x900? if so the super resolution you are trying to run is not scaling properly with the display. when set to 1920x1080 it is rendering a 16:9 ratio image then trying to squish it into a 4:3ish (WXGA+) frame which is causing the funky image.
super sampling is not great yet and won't provide more clarity than anti-aliasing
The best gaming PC is the PC you like to game on, how you like to game on it
My 1440x900 is 16:10, could that be the reason why it's not working properly?
Yes you would have to use either 1728*1080 or 1920*1200.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
yep, you could try 1920x1200 to match the scaling ratio of the image and see how it goes. So far my experience with supersampling hasn't been great as you can't increase the number of pixels without weird artifacts and blurry image from the monitor trying to figure out which pixel colour to send and causing a messy image.
I can't tell if it's blurry or not in game, but when I use it on desktop, the text is definitely blurry. So I guess it doesn't work properly then?
That's just how it works. Blurry is normal when it comes to super-sampling. You might have better results by sticking to integer multiples of your monitors resolution.
So 2880*1800 for instance. Or 4320*2700.
Edit:
1.5X might be a little better too. That would be 2160*1350.
Edited by HairlessMonkeyBoy
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
I guess that just creates a whole another problem , sacrificing smoothness for blurriness. I won't use it then, hopefully they can improve this in the future, if I don't get a new monitor by then.
Just run at 1440x900, with an RX 570 you can afford to turn all the bells and whistles up and stay at a locked 60. Supersampling isn't worth the performance hit, instead consider mods or overclocking your monitor to 75hz.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Thanks, I'll see what I will do.
