air bubbles go up, don't let air bubbles reach a part of the radiator/tank that makes moving water harder to do.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1246739-top-or-bottom-port/#findComment-14020613
the pump doesn't have to work that hard if the ports are on top
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1246739-top-or-bottom-port/#findComment-14020614
Each end of the radiator has a little reservoir. From what I gathered, ideally you always want one part of that above the height of the pump. With that being said, it's also preferable to have the tubes at the bottom of the radiator, so the non-tube end/reservoir is at the bottom of the radiator. This means that bubbles get trapped in the top of the radiator and won't travel through the tubes to the pump, because bubbles go up and can't get to the tubes, since they're at the bottom.
That's what I took away from it anyway.
Stop and think a second, something is more than nothing.
https://linustechtips.com/topic/1246739-top-or-bottom-port/#findComment-14021374
No.
Why is this so hard?!
  • Air must never go into the pump.
  • Air goes up.
So  tubes down  = Air stays trapped at the top of the rad and the pump always gets water and no air bubbles.
https://linustechtips.com/topic/1246739-top-or-bottom-port/#findComment-14021453
