I'm looking for an ATX case with preferably windowed side (it isn't needed) and good airflow, I found the Kolink Stronghold but I imagine that has trash airflow also found the Corsair Carbide SPEC-01 I really like the look it looks like those older gaming PC cases and I like the vibe. Any recommendations?  Edit: The motherboard will be mATX but ATX is just a bigger mATX
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1246390-looking-for-atx-case/
p500a should tick the boxes
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017834
Forgot to mention budget
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017837
4 minutes ago, Moonzy said:
Is that even buyable?
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017840
yes, it's a legit product
though the pricing is quite high
as for a proper case recommendation, the corsair you picked looked decent, airflow wise
or
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017857
or
  Reveal hidden contents
I think I might go with the corsair one I like the older corsair cases my main PC will use a carbide 200r (I will buy a dust filter for the top)
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017869
tbh the cooler master NR600 looks kinda neat
and not acryllic side panel, i think
acryllic scratches too easily
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017880
Yeah I considered the NR600 but it's to expensive, I think the corsair one is my best go here
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017889
bad news the CPU cooler I'm getting would not fit in the Carbide spec-01 should I switch CPU cooler or case?
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017910
4 minutes ago, _DeXTeR_ said:
Everything depend on money that you plan to invest and also do you want the case that comes with fans or empty case. Side glass panel right
I don't plan on investing too much since it will be a secondary PC, I would like a case that comes with fans since I only have a 92mm rn, Side panel isn't needed tbh so you could cut cost by not getting one with side panel
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017922
what cooler are you using? R5 3600 (or equivalent) right?
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017923
This is for my secondary build so it will be cooling an i5-8400, I was planing on getting the Arctic Freezer 34 eSports
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017929
Steve over at Gamer's Nexus is an absolute beast at testing computer cases.  He helped me pick a Lian Li Lancool II Mesh case.  Here's his page on the best airflow cases for 2020
https://www.gamersnexus.net/guides/3604-best-gaming-pc-cases-for-airflow-in-2020-right-now
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017935
Just now, Moonzy said:
stock cooler?
Nah some shit cooler that came with the prebuilt, Under load sound
CoolerTest.m4a
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017936
oh im asking why not use stock coolers
How would I get my hands on one?
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017945
oh you dont have it?
then i guess find another cooler
or get another case, up to you to decide which route is cheaper/better
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017952
Nope I don't have it since basically I will be moving a prebuilt PC to another case and call it secondary (the prebuilt had it's own cooler), I will probably get a non window sided case that can fit the Arctic Freezer 34 eSports instead
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017958
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017969
Just now, _DeXTeR_ said:
Well I gave you the links now you can search them in your country stores.
None of them is sold here
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017974
The BitFenix Nova Mesh looks lit and is not that expensive either
 BitFenix Nova Mesh Svart
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017976
honestly anything with a mesh front and holds enough drive that i wanna put in is good enough for me lol
case nowadays are all boxed with TG, no airflow, so mesh is good enough
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017982
Then it probably will be this case unless someone says something better
Reminder⚠️
https://linustechtips.com/topic/1246390-looking-for-atx-case/#findComment-14017985
