Aerocool VS92 in white
Mkfish
So this is my current rig, housed in what can best be described as "a polished turd", case.
I have done my best with the cable management but the lack of space is terrible, also the front panel connections are hideously un-braided and create quite the eye-sore. As does the obnoxiously blue USB3 front panel connection lead.
I will be purchasing a Corsair Vengeance C70 case in which to replace this thing with, at the soonest possible time. Probably in about 2 weeks. But for now here is the best I could muster with this case.
This is the first build I have done that I consider to have a modicum of professionalism about it. And is certainly the cleanest and most well constructed project I have put my efforts to. Any tips or pointers on future builds, or indeed when I upgrade the case are certainly welcome.
If you noticed there is no exhaust behind my push-pull CPU heatsink it's because it is still on the way, but the 2 fans in the top seem to be doing a pretty good job anyway. There is an additional 120mm fan in the front of the case but it has no LEDS so you can't see it. Specs are in the sig below :) Also the temperature sensor on the front is completely borked, it stopped reading accurate readouts after about 2 weeks (£50 ftw) and is only an ambient sensor.
post-56840-0-21492700-1394216755_thumb.j
post-56840-0-56358200-1394216758_thumb.j
post-56840-0-44717500-1394216761_thumb.j
post-56840-0-43284600-1394216764_thumb.j
post-56840-0-79900900-1394216767_thumb.j
post-56840-0-90013000-1394216770_thumb.j
post-56840-0-17437100-1394216773_thumb.j
// Gigabyte 990FXA-UD3 // AMD FX-8320 CPU @ 4.3 Ghz (7-21.5 Multiplier) 200.90mhz FSB CPU-Z Validated // Kraken X40 AIO - 2x140mm Push-Pull // 4GB Corsair Vengeance LP - 8GB Avexir Core Series Red 1760Mhz // Sapphire R9 Fury Nitro 1130mhz/4GB 1025mhz (Effective) GPU-Z Validation // Corsair SP2500 2.1 & Microlab Solo 9C Speakers // Corsair K90 Silver - Cherry MX Red & Blue LEDs // EVGA SuperNova 850w G2
Such nice RAM, though I'd rather get 16GB for less than 8GB of those..... :(
Nice rig! :)
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
