HDD not showing up HELP
JozefDuij
Hello,
Hopefully someone can help me! My 4TB western digital HDD is not showing up at all. I checked Bios and disk Management, and I changed out the Sata cables that it came with.  Drive spins, and sounds normal, but wont show up at all.  what should I do?  Just get a new HDD cause it was only $80 CAD so I don't mind getting a new one, but would like to find out why this one isn't working. Thank you
1 minute ago, JozefDuij said:
Hello,
First of all, I see that you're new around here, welcome!
Secondly, try a different SATA port on the motherboard. If you have a M.2 SSD, it's possible you may have used a SATA port that shares the same lane as that M.2 slot. Or it could just be a bad SATA port.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I have WD Blue SN500 M.2 SSD. and I tried all SATA Ports and nothing is showing up.  what that mean the motherboard is not good?  Sorry if im asking stupid question this is my first pc build and I am trying to learn.
What motherboard are you using? And do you have any other drives in the system, other than the WD Blue M.2 and the new HDD?
Knowing that makes it a bit easier to troubleshoot things.
Gigabyte B450 AORUS M Socket AM4 motherboard. no those are the only storage i have in the system
If memory serves me right, SATA 5 and 6 get turned off, because you have an M.2 SSD installed.
I would only be able to check this for sure later today.
As a sanity check, uninstall the M.2 SSD and see if the hard drive is detected in the BIOS. Then you know for sure if the SaTA ports work at all.
