Hey team pc some times dose not start. Just dead no power.  When power dose come back time in wrong in windows
Can't jump the mother bord. Can jump the power supply threw 24 pin no problem.
To fix it. Sometimes I open the case jump the power supply for 30 seconds put it back it press power and  I just wait and it randomly turn on after like 5 to 40 minutes  or I just try the power button ever 20 minutes or  so and it boots after a while. Maby 20 mins to an hr or 2
Cpu 8600k
Mobo msi z370 a pro
Gskill ripjaw ddr4 3200
Amd 5700xt
Some ssds
Thermaltake Smart 700w 80+ power supply
Do I try a new mobo first then power supply since the power supply jumps no problem??
I’ve tried changing the power button and reset button around. I tried jumping the motherboard with a screwdriver. Tried changing the CMOS battery. I unplugged everything and re-plugged everything back in ect
https://linustechtips.com/topic/1245262-pc-wont-boot-sometimes-help/
Cpu 8600k
Mobo msi z370 a pro
Amd 5700xt
Some ssds
* Threads merged and moved to the Troubleshooting section *
Please, do not double post, it's not allowed on the forum.
If you need help with your forum account, please use the Forum Support form !
I believe there are some double post problems. They seem to be identical.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
 ... there's no problems, please take the time to read moderator's messages ;
Also, discussing moderation is not allowed.
Edited by wkdpaul
