Hi,
I just bought an Inter-tech C-701 Panorama which is pretty much the exact same as a Xigmatek Aquarius, or the Tecware VXR and I wanted to see if anyone that has either of those cases has fit a E-ATX motherboard in it? I'm wanting to fit an AORUS TRX40 Master into it which is just 2.5 CM bigger then a ATX motherboard. I think it will fit with no real issues but wanted to ask on here to be sure if at all possible. I really really really want it to fit into the Lian Li PC-011 Mini that will be out at the end of the month but we'll have to wait for it to be out to get the proper dimensions.
Thank You
https://linustechtips.com/topic/1244641-will-it-fit/
11 minutes ago, Vulcanrvn90 said:
Will it fit?
Thats what she said.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1244641-will-it-fit/#findComment-14003393
it fits, just lose the cable pass throughs on the bottom and the leftmost screw access to the "front" fans.
if you plan the build out and don't need a bottom most dual slot graphics card, or the 3 fans with a rad on the front side of the case there's no problems, skip the rad and you can run the fans behind the mount and still have all 9 in the case
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1244641-will-it-fit/#findComment-14003406
You 3 are awesome, those were my thoughts exactly I just wanted to make sure, you know get a second opinion. I plan on just running a single 3080, a quad nvme card, and possibly a thunderbolt/10g lan card so no worries on that end. I wanted to do a 260 rad on the front/right if possible, but if I must, ill rock it all air. Mounting the fans behind the mounts for the front portion will still be effective?
My other option is to try my best to get this setup into the new Lian Li pc-011 mini that comes out at the end of the month, god I hope it all fits but I think even using an atx case its a tight fit so idk about this master, even though it would only be a little less then a inch more wide.
Thank You
https://linustechtips.com/topic/1244641-will-it-fit/#findComment-14007703
