so i recently bought new parts for computer which are an asus maximus 6 formula i7 4770k another gtx 780 ti and 1000w psu so when i connected everything and turned it on after a couple of minutes computer turned off so i thought it was because i either mounted the h100i wrong or i added to little or too much thermal paste so i re did it and tried to start it and it did not start i noticed the republic of gamers logo on the motherboard was blinking tried looking in motherboard manual to see what it meant i couldnt find something about(or maybe i didnt see it) so than i thought it was the psu so i removed it and installed my old one which is a ax750 which i new wasnt guna be enough to power the dual cards and motherboard so i removed one card and installed everything again and turned it on and it worked for 30 minutes than while playing league turned off again and wont turn on now im here i do not know what is wrong and im confused maybe i messed up on mounting the h100i again or something someone help me
System Specs~~~~~
Case-Corsair Air 540                                   CPU-i7 4770k                           Ram-Corsair Vengeance 16 Gbs    PSU-Corsair RM1000
Motherboard-Asus Maximus VI Formula    Graphics-Asus Gtx 780 Ti x2     CPU Cooler-Corsair H100i               SSDs-Corsair Force GS 128/360 Gb
https://linustechtips.com/topic/124447-computer-problems-idk-confused/
Try finding your temps, I think CPUid works for that, if not use after burner for GPU.
Im not much of a hardware trouble shooter...
Are you sure you have everything plugged in?
yea it turned on for 30 minutes than it turned off by itself and now the logo "republic of gamers" is blinking and it wont turn on
System Specs~~~~~
the computer wont turn on
System Specs~~~~~
Will it stay on on the bios for more than 30 minutes? (I remember having problems with my formula.)
it will not turn on cant get in bios
System Specs~~~~~
