Hello guys
i am building a workstation PC and i need some help here. the usage will be for 3dsMax, auto-cad, Photoshop, light room, revit, vray and corona render
so please tell me your recommendation parts for the built depending on your experience in the field
because too much confused between the parts like RYZEN or INTEL
and which part should be higher the CPU or GPU ?!
QUADRO or RTX
BUDGET 2000$ USD
https://linustechtips.com/topic/1244364-2000-workstation-required/
3 minutes ago, Ahmed Hafez said:
corona render
kek
Location?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Just now, Ahmed Hafez said:
UNITED ARAB EMIRATES
ALRIGHT HERE YOU GO
PCPartPicker Part List
CPU: AMD Ryzen 9 3950X 3.5 GHz 16-Core Processor  (2918.10Dh @ Newegg UAE)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  (647.75Dh @ Newegg UAE)
Memory: G.Skill Aegis 64 GB (4 x 16 GB) DDR4-3200 CL16 Memory  (881.10Dh @ Newegg UAE)
Storage: PNY CS2130 2 TB M.2-2280 NVME Solid State Drive  (1088.81Dh @ Newegg UAE)
Video Card: ASRock Radeon RX 5700 XT 8 GB CHALLENGER D OC Video Card  (1701.95Dh @ Newegg UAE)
Case: Phanteks Eclipse P300 ATX Mid Tower Case  (514.99Dh @ Newegg UAE)
Power Supply: Corsair CX (2017) 650 W 80+ Bronze Certified ATX Power Supply  (497.44Dh @ Newegg UAE)
Total: 8250.14Dh
Generated by PCPartPicker 2020-09-08 13:05 +04+0400
I would wait a month for the RTX 3070, but if you want it now then build this.
25 minutes ago, Ahmed Hafez said:
Hello guys
QUADRO or RTX
BUDGET 2000$ USD
PCPartPicker Part List: https://ae.pcpartpicker.com/list/dFDVsk
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  (1867.52Dh @ Newegg UAE)
CPU Cooler: Cooler Master MasterLiquid ML240L RGB 66.7 CFM Liquid CPU Cooler  (501.33Dh @ Newegg UAE)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  (703.40Dh @ Newegg UAE)
Memory: G.Skill Ripjaws V Series 32 GB (4 x 8 GB) DDR4-3200 CL16 Memory  (576.04Dh @ Newegg UAE)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  (502.05Dh @ Newegg UAE)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (297.84Dh @ Newegg UAE)
Case: Cooler Master MasterBox TD500 Mesh w/ Controller ATX Mid Tower Case  (787.86Dh @ Newegg UAE)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (738.63Dh @ Newegg UAE)
Custom: RTX 3070 (1800.00Dh)
Total: 7774.67Dh
this should set u up for workstation use , it includes an AIO liquid cooler , 3 Tb of space and rtx 3070(not released yet , it will release in october), 32 gb ram ........ 12 cores , i wouldnt spend an extra 1000 dh for a 3950x
You Think B series of the motherboard will be fit for the workloads for a long time ?
for sure B series MOBOs can support workloads for a long time , the X series boards are just a higher end model but there aint much difference between them and make sure to get a b550 mobos if choosing B series since they have pci gen 4 which doesnt even cost much more than b450 , the new rtx cards benifits a small percentage from pci gen 4
Total: 7774.67Dh
thank you for your help
but i still have this quistion does the B series of the motherboards will be fit for the workloads for a long time ?
i think x570 is will be better like  asus x570 tuf gaming plus
what u think ?
what u think ?
i would say b550 boards will be amazing for workloads but after all u are spending money , so IF u want u could go for X570 boards but x570 mobos hav inbuilt fans and i have seen some situations in which  people say the fans are too loud , X570 mobos are amazing ... not much difference the x570s have a better chipset , nothing more than that
1 hour ago, Ahmed Hafez said:
thank you for your reply
I searched now and found it supports only 1 GPU
and i am planning to have 2 gpu in the future so i think b550 not what i need right ?
Actually b550 ATX motherboards does support dual gpu but there is a problem , as far as nvidia had told , THERE IS NO SLI SUPPORT FOR RTX 3070 infact even the 3080 doesnt have sli support , so its Absolutely useless for getting dual GPUs ..... dual gpus were a part of the past .... there is literally Very minimum performance increase with dual gpu and its not recommended to run 2 different gpus on the same pc since it has a chance of damaging some of the components ..... RIP SLI
coming back to your subject , yes the b550 mobo i recommended does support dual gpu , but it has only one lane of pci gen 4 , but is the same case with x570 boards at this budget , but of course the more u spend , the more benifits ,so if u get more expensive mobos, some of them have 2 lanes of pci gen 4, so its according to u to get b550 or x570
Autodesk does recommend going with Quadro for their suite though (so Autocad and Revit in your case), so you could go with an RTX 4000 but then you'd have to sacrifice on most other components in the build.
Also if you need to build the system now, swap the 3070 out for a 2060 Super.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
