my current specs are
CPU: i7-9700k (no oc)
GPU:GTX 1070TI
4x8gb ram 3200mhz
mobo  asus z390-a
I use 2 ssds and 1 hdd
PSU coolermaster b700 bronze
so here is my question: I want to upgrade to the rtx 3080 but idk if my 700 watt power supply will be enough the handle it. Do I have to upgrade my psu or can I keep using my current psu?
https://linustechtips.com/topic/1244011-need-advice-about-psu/
It will be enough. So many people ask this question.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1244011-need-advice-about-psu/#findComment-13998395
not sure if this is a good PSU, but you should pair a high end rig with a high end PSU
as for your question, 700W is enough
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1244011-need-advice-about-psu/#findComment-13998403
There's been a few B series PSUs from Cooler Master. None have been any good. Was there even a 80+ Bronze rated B700?
Definitely wouldn't use it with an RTX3080.
Do you have the exact model of the PSU? Should be like RS-700-A_____? Or just a photo of the label on the PSU
Edited by Spotty
https://linustechtips.com/topic/1244011-need-advice-about-psu/#findComment-13998439
