8 minutes ago, VexPoxLV_ said:
Hey!
Help me build a new pc. My budget is 1000 euro. The pc will be used for gaming and for work.
Thanks!
Just wait rtx 3000 is launching. The 3070 is probably possible in your budget or worst case you snag a 2080ti used for cheap. Either way you'd get a lot more power for cheap.
https://linustechtips.com/topic/1243550-help-me-build-a-new-pc/#findComment-13995149
