Need help with pc upgrade for rtx3070
Solved by LIGISTX,
5 minutes ago, Dablar said:
Im planning on buying a rtx3070 but i dont know what i need to upgrade, im playing on 1080p 144hz
Ive been told my psu could blow my pc up so i think thats a start
I really need to replace that corsair vs right now or i could wait? any recommendations?
Will my cpu bottleneck the gpu too much? I can wait for the 3060's if so
thanks!
Definitely need a better PSU.
If your playing at 1080p... I wouldn't even get a 3070. Thats trying to kill an ant with a nuke. I would wait to see what the 3060 looks like and get that. If the stack rolls out like the top 3 cards do, the 3060 will likely be a 2070 super or 2080 performance for 399. For 1080p............... thats a LOT of power.
