Hey :)
Do RAM speed and timings (CAS latencies) matter that much outside of gaming?
On intel vs AMD (infinity fabric) platforms?
If yes, in what kind of scenarios will the difference be most noticeable?
Video encoding/transcoding?
3D apps like industrial/scientific imagery?
Thanks
https://linustechtips.com/topic/1242814-ram-speed-timings/
Some programs prefer bandwidth over latency and others prefer latency over bandwidth, depends on what workload.
if it's just an office build/ a build used for casual use with no heavy workload, it doesn't really matter.
Also even though intel doesn't use a ccd and multiple ccx's, that does not mean latency isn't a thing on those cpu's, it's still a thing.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1242814-ram-speed-timings/#findComment-13989513
This is a long video but it's got a loooot of great info about how to overclock AMD CPUs and what matters.
So yes, RAM Speed and timings do matter for performance, in fact you can see a huge difference between RAM Speeds in the i5-10400 review here.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1242814-ram-speed-timings/#findComment-13989516
