so basically here's the problem i have a monitor right and an XP Pen 22E Pro drawing tablet which have worked fine since i got it until yesterday, yesterday when i tried to boot up my PC everything would be black and that's it so i did a lot of things but what fixed it was was unplugging the HDMI going to my drawing tablet and then the PC booted up so i decided ok well it's booted so i should be able to plug my drawing tablet back in but no as soon as i did that everything went black on my main monitor and the drawing tablet says No Connection and i'm on the latest drivers for my graphics card and the latest drivers for the drawing tablet and i have been for like a week or 2 so i don't think it's the drivers the only thing that comes to mind that might've messed something up was that i tried overclocking my main monitor in the NVIDIA control panel so you know i went in and made a custom resolution and set it from 60HZ to 75HZ and clicked test everything worked fine and didn't gimme any error at the time i even went and played warzone and everything was fine but at the end of the night when i tried to turn off the PC the screen was glitching out so i held the button on the PC to turn it off and i left it like that which was a dumb thing to do but i did and then the next day AKA yesterday is when all of that that i wrote above happened
so please can anyone help me PS. when i plug in the drawing tablet by itself it works fine but as soon as i plug the second thing (My Monitor) everything still goes black and i checked the cables IDK if this counts but i just used the HDMI cable with my PS4 and everything was fine
https://linustechtips.com/topic/1242120-help/
your topic title should probably be changed
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1242120-help/#findComment-13984001
1 minute ago, JoshuaProGamer said:
to what?
maybe something like "tablet not working suddenly"
most users' eyes glaze over when we see a topic title that's just "help" or "urgent"
are you able to test your tablet on another PC
Primary PC:
PSU tier list
https://linustechtips.com/topic/1242120-help/#findComment-13984012
no but like i said the "the drawing tablet by itself it works fine but as soon as i plug the second thing (My Monitor) everything still goes black" it's just when i have both the monitor and drawing tablet connected that everything goes to black and then i need to restart the PC and only have 1 plugged in or it wont boot
https://linustechtips.com/topic/1242120-help/#findComment-13984018
What do the windows display settings say about how many monitors are connected?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1242120-help/#findComment-13984031
like i said if i have both connected everything goes to black so i can't troubleshoot or check anything and when i have them by themselves it works fine and shows up as the correct Monitor/Drawing tablet
https://linustechtips.com/topic/1242120-help/#findComment-13984037
-= Topic moved to Troubleshooting =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1242120-help/#findComment-13984273
