How much VRAM do I need for future-proofing?
I play with a 1080p 144hz monitor and I am thinking of buying the 3070. The question is, how much VRAM do I need for future-proofing (using the card for 6-7 years without it performing poorly)? Is the 8GB VRAM in 3070 enough for me? Or should I buy the 3080?
Let me know what you people think. Also, here's my current rig:
i7 8700k (stock)
16GB DDR4 RAM
GTX 1060 6GB
https://linustechtips.com/topic/1241968-how-much-vram-do-i-need-for-future-proofing/
3070 should be good enough for 1080p 144hz even with RT on,
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
8GB of VRAM is plenty for 1080p and 1440p at 144hz. If you were playing at 4K, I might recommend the 3080, but the 3070 should be fine for your needs.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
you can't future proof normally, but even if you could somehow decide on an amount of ram that is "immune" to the effects of time, cards only come in one variant. If you want a 3070, you're getting 10GB, that's that.
if you got your crystal ball working though, i'd love to know the winning lotto numbers if you don't mind
Primary PC:
PSU tier list
How many watts do I need?
Thanks! I was getting very skeptical of 3070 when I've read what people have been talking about (like how 8GB VRAM is bad etc.)
I assume you wanted to say 3080 not 3070 😄
In case of future-proofing, I'm talking 6-7 years of usage without the card performing poorly (in games) and I know this is a weird question because we don't know how games are going to be in 6-7 years but I'd like to know what is on others' minds.
poorly is such a subjective term.
What is guaranteed is that a high end card of today is not a high end card in 7 years time, you can definitely not pull off 4K high at 60FPS in newer and newer AAA titles.
There seems to be a perception that the more money you spend now, the better a chance your GPU will still be "powerful" after a long time, but the trend is generally that it slowly becomes weaker in comparison. therefore, don't plan for the future, plan for what you currently want and see how your gaming expectations evolve over time.
Primary PC:
PSU tier list
Great answer, thanks!
In case of future-proofing, I'm talking 6-7 years of usage without the card performing poorly (in games) and I know this is a weird question because we don't know how games are going to be in 6-7 years but I'd like to know what is on others' minds on this topic.
Well you would probably swap your RTX 3070 before you reach 6 ~ 7 years.
Going back 6 ~ 7 years from 2020 .... would be GTX 700 series.
Compare a GTX 780 to RTX 2080 Super?
No comparison.
By 2026 ~ 2027 we would be on RTX 10,000 series (or whatever numbering nVidia decides to use).
Assuming new GPU release every year or so.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
No comparison.
That is very accurate of a response.
I know that swapping is inevitable, but I really would like to go as far as I can with a brand new card.
