   I want to rebuild my father's old emachines computer as a sleeper pc, but on a budget. If anyone has ideas, suggestions, advice, or have a build that is similar, then I would be glad to listen. As you can see in the pictures of the computer, the machine has an Intel Celeron 325 D processor, a 40GB hard drive, a Combo Drive (it reads both cd's and dvd's), and 256MB of DDR SDRAM. It will not POST due to a broken pin on the cpu, but all the other systems, (including the mouse, keyboard, and monitor), seem to be in working order. It currently runs Windows XP.
https://linustechtips.com/topic/1241510-emachines-pc-rebuild/
Use spoilers next time, saves me 20 seconds of scrolling.
That looks like it should fit any micro ATX case, modern PSU, etc. Might have to do some ziptie engineering for cable management, fans, and storage, but it should be fairly easy.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1241510-emachines-pc-rebuild/#findComment-13979689
Holy crap, I had this exact model eMachines for a while, still have the case.
If you're going to build a sleeper, just realize that you won't realistically be able to use the optical drive. It's IDE and any motherboard made in the last decade is going to have SATA-only for attached drives. There are adapters, but honestly I would just skip the optical drive functionality. Also, if I remember correctly these old cases have little "humps" in-between the expansion card slots, so you'd need to break one off if you're using a double-slot graphics card (do this before you install the motherboard). It is standard mATX, and the power supply is a standard ATX.
The biggest issue though is that airflow is catastrophically bad in this case, there is not really a front intake at all, and I think the rear fan is either an 80mm or a 92mm. If you wanted to make a Ryzen-based APU setup you'd probably be OK, but adding a discrete card is going to cause overheating problems.
I had a Phenom II X6, GTX 750Ti, and a 500 watt EVGA power supply crammed into my case just as a test, the only way I could keep it from melting down was to cut a hole for a 140mm fan on the side panel right over the graphics card, and put a grill over it. This worked, but it really did away with the pure sleeper aspect.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
https://linustechtips.com/topic/1241510-emachines-pc-rebuild/#findComment-13979757
23 hours ago, Caroline said:
Well it can take new components.
Depends on how much you're willing to spend on the upgrade. If you get a midrange+ graphics card then get an expansion slot cooler (the big workstation/server models, not the tiny blowers) to have some air intake or it'll be a furnace.
The PSU will have to act as an exhaust so make sure it's a somewhat decent unit and not some noname china tin can.
You can get a new ODD to replace that old model and it won't look bad because of the front cover.
I believe on these old eMachines, the cover for the disk drive is actually part of the drive unit. It's not something you can pop off and stick onto another drive or simply slide into the case and have the button and lights line up.
eMachine SM-348B/TG11 6X 48X/24X/48X IDE DVD-ROM/CD-RW DRIVE |  RecycledGoods.com
On 9/1/2020 at 2:14 PM, NuclearNerdz said:
-snip-
Whatever you do with it, please keep the stickers! Those stickers are so period correct. You don't see those anymore.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1241510-emachines-pc-rebuild/#findComment-13983848
