Some achievements require you to do other things than just play the storyline.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/124136-far-cry-3-problem/#findComment-1651446
Yeah, but i did the things that the achievements ask.
If you didn't get the achievement pop-up then try do them again.  Look for other people doing them on YouTube, you might be doing them wrong.
https://linustechtips.com/topic/124136-far-cry-3-problem/#findComment-1651451
I mean the achievements you get in the storyline, like "Save your friend before he is sold as a slave".
Oh, if you've done them but didn't get the achievement then the only thing you can do is replay that part of the game.
https://linustechtips.com/topic/124136-far-cry-3-problem/#findComment-1651462
So i have to do the whole story again?
Just those parts which you need to get the achievement.  It's unfortunate but I don't know of any other way you could get them.
https://linustechtips.com/topic/124136-far-cry-3-problem/#findComment-1651467
Yeah, for those sorts of achievements the best and only way I've seen is to replay that part.
I've had that problem with Steam also, mainly with Bethesda games F3,FNV and Skyrim have all done it.
Fallout I had achievements for getting like level 30, but was missing level 5 ones, that sort of thing.
Also had Skyrim for defeating Alduin, but not for finishing the first Greybeard quest.
Starting a new character unlocked the Skyrim ones for me. It can just be a bit iffy it seems.
CPU: 6700k GPU: Zotac RTX 2070 S RAM: 16GB 3200MHz  SSD: 2x1TB M.2  Case: DAN Case A4
https://linustechtips.com/topic/124136-far-cry-3-problem/#findComment-1651816
