Specs
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651067
Wouldn't you want SP fans on a radiator? Or am I getting confused? :S
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651073
their 120mm fans they would fit on the rad (2 per side)
Specs
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651077
Of course they would fit, but AFAIK AF fans are made to go on cases and SP fans are made to go on radiators.
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651084
Take a look at this:
http://www.tomshardware.co.uk/answers/id-1730004/corsair-fans.html
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651087
oh wops meant to select static fans my but @paraletic any static pressure corsair fans will look fine
Specs
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651093
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651114
Probably Arctic F12 PWM CO's.
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651120
Can anyone tell me what the best normal looking, good performing and kind of affordable fans are to replace the stock fans on the Corsair Hydro H100i?
Also, I do live in Europe.
Maybe you could tell us what you consider good performing and give us a budget to work with. You know that could help us better assist you.
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651133
2 fans for a maximum of 40bucks.
Scythe Gentle Typhoon 1850 RPM x2, Noctua NF-F12 x2 or SP120 (quiet or performance up to you) x2
https://linustechtips.com/topic/124112-h100i-fan-replacement/#findComment-1651289
