Hi
I have 2 floatplane problems
the floatplane support form is broken. it asks for a topic from the pull down list, but there are no topics to choses. and the form will not finish without a topic. have tried in both chrome and edge, with the same result
which leads me to the reason I was trying to contact floatplane.
in the new iPad app
if your iPad is set to dark mode and you need to log in to the app. it is very hard as the user name and password fields are using white characters on a white background. you have to switch the Ipad to light mode to log in so that you get black characters on the white background.
Greg B.
https://linustechtips.com/topic/1240824-floatplane-problems/
