First PC build
Solved by Kai Alter,
Budget (including currency): 1,000 USD
Country: USA
Games, programs or workloads that it will be used for: Streaming on twitch, video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'll plan on building a PC sometime soon to stream games to my Twitch channel. starting on a low budget but will upgrade parts as needed later
