Specs are:
ryzen 5 2600x
gtx 1050 ti
cooler master masetliquid ml240l rgb stock fans
and 2 corsair fans wich i got with my other aio
asrock ab350m pro4
the problem i have with this is that i keeps having the same noise level and it is rally loud and it is really iritating me so it would really help me if someone replied witl some help
https://linustechtips.com/topic/1239896-noise-problem-in-my-pc/
2 minutes ago, brammethie said:
Specs are:
ryzen 5 2600x
gtx 1050 ti
asrock ab350m pro4
Go into the BIOS and adjust your fan speeds. So how far that gets you first. Other than the 2 fans that came with your AIO liquid cooler, do you have any other fans? Are you using a reference GTX 1050Ti?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1239896-noise-problem-in-my-pc/#findComment-13966745
case? pictures?
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1239896-noise-problem-in-my-pc/#findComment-13966747
On 8/28/2020 at 9:44 PM, Caroline said:
If those 2 extra fans are Corsair 120mm fans then boy those will be loud running at max speed.
Which ones are loud though?
That’s the problem I don’t know which one and the other problem is that I don’t know why they are running so loud
https://linustechtips.com/topic/1239896-noise-problem-in-my-pc/#findComment-13980260
I got a 1050 ti windforce from gigabyte I don’t exactly know because I got it from a friend and I got some other Corsair fans and I got 4 or 5 of them
https://linustechtips.com/topic/1239896-noise-problem-in-my-pc/#findComment-13985961
