I been having power state fails and do not know what driver is causing it.
Here is the crash dump/minidump
Thanks
Crash dump directories:C:\WindowsC:\Windows\MinidumpOn Wed 8/26/2020 9:13:39 AM your computer crashed or a problem was reportedcrash dump file: C:\Windows\Minidump\082620-8343-01.dmpThis was probably caused by the following module: ntoskrnl.exe (nt+0x3DDF40)Bugcheck code: 0x9F (0x3, 0xFFFFE00EF698E830, 0xFFFFF8033406C750, 0xFFFFE00F118A7760)Error: DRIVER_POWER_STATE_FAILUREfile path: C:\Windows\system32\ntoskrnl.exeproduct: Microsoft® Windows® Operating Systemcompany: Microsoft Corporationdescription: NT Kernel & SystemBug check description: This bug check indicates that the driver is in an inconsistent or invalid power state. A device object has been blocking an IRP for too long a time.This is likely to be caused by a hardware problem.The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
I have 4 more crash dumps but they are all the same as this.
https://linustechtips.com/topic/1239815-driver_power_state_failure/
https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/bug-check-0x9f--driver-power-state-failure
here is microsofts documentation on this matter
what i would do: uninstall and reinstall your drivers
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
> Moved to Troubleshooting
If you open Device Manager are there any cautions indicating a driver issue?
What are your system specs?
How long has this been happening, and has anything changed that may have caused this?
my specs are i9 9900k oc at 5ghz all core,msi z390 godlike,newest bios,msi 2080,64gb g skill ram at 3000 mhz,windows 10 pro,and over 20 usb devices
temps are fine
I recently reset my pc because of another issue and that was fixed but then like the last week i would get power driver state failure,when i boot up from shut down everything works but when i go to sleep and do a wake up from sleep the rgb lights do not sync then the power driver state fail .I have a 1600w psu so its not a power problem
For drivers in device manager has problems i have nahimic mirroring device,but there are 2,1 has an error and the other is fine.There is one other driver some usb device,pics below.
Thanks
could those driver be causing it or should i just reset the pc,all my files re backed up
  • 2 weeks later...
so its been a few days, wiped all drives, fresh install of windows 10 pro, after getting everything set up again I am still having the same problem
crash dump , its different this time, at least the number and letter code thing
On Sun 9/6/2020 10:10:13 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!MmTrimAllSystemPagableMemory+0x28937)
Bugcheck code: 0x9F (0x3, 0xFFFF9389ED231A80, 0xFFFFF8027F66C750, 0xFFFF9389F6DB1850)
Have you tried replacing the RAM? Looks like faulty RAM.
I have more crash dumps from the last 2 days that might help
On Mon 9/7/2020 6:33:35 PM your computer crashed or a problem was reported
Bugcheck code: 0x9F (0x3, 0xFFFF93872CE1E520, 0xFFFFF8006F26C750, 0xFFFF938737A9D9A0)
On Mon 9/7/2020 11:36:26 AM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\090720-25921-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F3EA0)
Bugcheck code: 0x9F (0x3, 0xFFFF948F92921D50, 0xFFFFF8054906C750, 0xFFFF948F9A8D09E0)
crash dump file: C:\Windows\Minidump\090720-33218-01.dmp
On Sun 9/6/2020 10:39:44 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\090620-27109-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFBC014214BD40, 0xFFFFF8016F66C750, 0xFFFFBC0154A19010)
crash dump file: C:\Windows\Minidump\090620-12234-01.dmp
On Sun 9/6/2020 10:04:18 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\090620-9296-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFF870BB86C3D60, 0xFFFFF8013906C750, 0xFFFF870BC10039A0)
  • 5 months later...
Was having this issue for a good year. The fix for me was my ASUS x99 motherboard had it's AI suite software and that installed a bad usb3hub driver found to be the cause in my dump files. After I uninstalled the software I haven't had a bluescreen since. You might have to uninstall that usb3hub driver. Similar to the driverhub you had.
In general if you look at your last dump file with windbg it will tell you what the cause is. You might be able to just uninstall the driver shown in that dump.
Hope this helps.
