You can see on the right and on the left there's two RGB systems, both different colors, White/Black. I noticed how in the black -themed build, the RGB looks pretty different from the White-themed build. Is this because of the Difference between the LEDs in the cases, or is it because of the color/darkness/reflectivity inside the cases? Could this be about the camera used to film it?
Ty
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1239639-does-casecomponent-color-affect-rgb/
The RGB appears dimmer on the white build because the studio lighting used to film this video is causing a lot of reflection, which is overpowering the RGB. In normal conditions, a black PC build with RGB will probably stand out slightly more than a white one, but I don't expect it to be nearly as obvious as it is here (unless you live in a movie studio, of course).
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Alright. Is this true for the vibrancy of the RGB too?
Yes, of course it affects it. Way more on the camera, but still noticably.
Same if you had RGB lights in a room painted completely black vs completely white.
In real life, I act like I know less about tech than I actually do.
Main build: CPU: AMD Phenom ii X4 955 Black Edition @ 4,0GHz (Cooler Master 212) | GPU: MSI RX580 8Gb | RAM: 12Gb DDR3 | PSU: Chieftec CTB-500S  | Mobo: Asus M4A87TD/USB3 | Storage: Seagate 500Gb HDD
Yes, I'm aware my CPU is a huge bottleneck. No, I don't really care.
Laptop: Asus TUF FX505DT 60Hz 8Gb model
"Fortifications, cannons and foreign aid won't help unless every man knows that he himself is a guardian of his country"
-Carl Gustaf Emil Mannerheim
