Whenever I try to listen to myself on the PC, there's always this annoying buzzing sound to which I thought was the headphone mic's fault. But then I while listening to myself and touching the case, the buzzing sound goes away entirely. How can I fix this?
https://linustechtips.com/topic/1239609-buzzing-sound-from-microphone/
Not grounded properly.
Check and make sure there aren't any wires pinched or exposed inside the case.
Make sure the PSU power cable is in good shape and change outlets to see if issue still happens.
If it goes away, then there is a problem with that power outlet.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
