Same API, different generations: same image quality?
Does a new generation graphic card produce a better image quality than an older card when comparing the same API? For example OpenGL or DirectX, I wonder if two cards implementing the DirectX 11.0 API would produce the same output or if the new gen card produce a better image?
If the cards are running the same settings and API, they would produce the same image, theroetically.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
Provided that all other settings are identical, they should produce identical pixel colors and arrangements, just with a more powerful GPU producing them at a higher rate.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
