Please help me!
Go to solution Solved by mohsenation,
1 minute ago, Giasgirl said:
This is what’s on the flash drive now it’s finished
Looks right. Plug it in into a usb 3.0 port in the motherboard IO (The one with the blue plastic) and hope for the best. Good Luck.
Pc build;
msi x570 gaming edge wifi
ryzen 7 3700x
corsair vengeance rgb pro 2x8gb
gigabyte windforce rtx 2070 super
seasonic focus 750w
nvme m.2 250gb wd black
500gb ssd wd velociraptor
it powers up, let’s me enter the boot setup but the usb drive isn’t in the list and I have no idea what to do! I’ve never built a pc before and me and my son did it together, I’ve checked the cables twice, no idea what to do, literally want to cry 😭
https://linustechtips.com/topic/1239566-please-help-me/
Just now, tank234 said:
I am assuming that you are talking about the windows usb stick. Have you tried different usb ports? and maybe try using a different usb stick
Yes the windows boot usb, tried both usb 2 ports, my son said the flash drive isn’t usb 3 so not to put it in that one, just redownloading the windows files in case there was something wrong with the first download
https://linustechtips.com/topic/1239566-please-help-me/#findComment-13964010
Just now, mohsenation said:
1) Try plugging it in from the back.
2) Try using different USB sticks.
3) check if the Windows Installation is correct.
As long as you are able to enter the BIOS settings you are good.
Good Luck!
Going to search for another usb now, we don’t use them often
https://linustechtips.com/topic/1239566-please-help-me/#findComment-13964013
2 minutes ago, Giasgirl said:
Should I try it in the usb 3 or is the kiddo right?
Doesn’t matter the version, did you go through the whole download setup?
you have to launch the program that’s downloaded and setup your usb
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1239566-please-help-me/#findComment-13964033
I think so, it says ‘creating windows 10 media’ and the progress and when it finishes I eject the flash drive
https://linustechtips.com/topic/1239566-please-help-me/#findComment-13964060
1 minute ago, mohsenation said:
I suggest you wait until it says finish the process and wait till the program exits.
Then you could proceed with removing the flash.
Yeah I mean I think it’s downloading correctly, this is the 2nd attempt as it wasn’t recognising the usb to boot from the first time
https://linustechtips.com/topic/1239566-please-help-me/#findComment-13964082
