Macrium Reflect Question / Help Please
Go to solution Solved by Kilrah,
"Clone this disk" just makes the 2nd drive an identical copy of the fist, always has. Obviously overwrites anything already on.
"Image this disk" makes a .mrimg image of the whole disk as a file and you can put multiple on one disk.
Why does it always overwrite the whole "target disc" when I clone my OS drive?
I don't really get it, isn't that exactly the point that you have several backups of the data you want to copy / backup / clone?
And yes,  there's enough space on the target disc,  it doesn't matter it'll always say "all data on target disc will be overwritten".
Just wondering if I'm missing something like a setting?
It really doesn't make sense to me - and is a massive waste of storage space because I never can use the "target disc" for other stuff since apparently,  in case I want to make another clone that would be overwritten...
-Scott Manley, 2021
https://linustechtips.com/topic/1239526-macrium-reflect-question-help-please/
Becasue you're using clone and not image?
F@H
GPD Win 2
Yeah, the weird part is I did that several times before and it always created a "MRIMG" file...  but now it just seems to copy my OS drive 1:1...
So what do I use to make a 1:1 "backup" of my OS drive then?
There doesn't even seem to be an option for that,  I just see "create an image of the partitions required to backup and restore windows"
I don't want that,  I want it to backup the whole drive.
It's really confusing because as said I already did this several times,  always used "clone this drive" and the result always was a "MRIMG" file... Well until yesterday... Even weirder I did it a second time afterwards and *then* it created a "MRIMG" file.
So yeah I'm confused lol,  but yeah,  I need a backup of the "whole" drive,  including the windows installation of course...
-Scott Manley, 2021
F@H
GPD Win 2
"Image this disk" makes a .mrimg image of the hwole disk as a file and you can put multiple on one disk.
Thanks,  that worked.  I really have no idea why this is so confusing, especially visually...
-Scott Manley, 2021
