I am having an issue where when I scroll down with my mouse wheel sometimes it will start moving up before down or sometimes during scrolling it will randomly scroll up before continuing going down. This also happens when I scroll up. My mouse wheel moves normally and doesn't get stuck when I move it.
Would this be a mechanical issue and is there a fix for it?
Thanks
My mouse is a Logitech G403
Do you play football/soccer?
Cause you look like a left-back
https://linustechtips.com/topic/1238775-issues-with-mouse-scroll-wheel/
You should be able to buy a replacement scroll wheel, an RMA is your best option.
Kogan 144hz monitor (Overclocked to 165) Ryzen 3 3100, RX 580 Gigabyte Windforce (1450 mhz) 2 x 8GB CL15 DDR4 3133 (Overclocked from 2400) Phanteks P300 white (RGB set to purple), Zarrius Deskpad (I have the yellow one), Razer Deathadder Essential, CK62 wireless (don’t use it wireless)
If its mechanical it might just be some crud in the scroll-wheel blocking the light-sensor from functioning properly.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
Thanks
I had that issue with my old Mionix Castor. Took it apart ti see if I could fix it, saw nothing wrong but cleaned it anyway and issue was still there so I bought a new mouse.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
