Concerning Temps
Go to solution Solved by Oshino Shinobu,
Those temps are fine really. I'd expect it to be a difference in fan curve or idle settings on the PSU. You'd need to be comparing fan RPMs and noise levels to really get a meaningful comparison.
The main thing you want to look at is load temps, and yours are absolutely fine. If you really wanted to bring down idle temps, you could adjust the fan curves but the system would get louder at idle.
For reference, my system idles at 40-50C on the CPU and 50C on the GPU, but that's with the CPU fan at 600RPM and the GPU fans off, as well as the PSU fan off, so the system is as close to silent as it can be. Under load neither goes far over 65C
Hey guys,
Not sure if this is the place to be asking this, but I had a quick question about my computer. I built a PC a few days ago and apart from the power supply, my friend and I have the exact same specs. We're using Cooler Master NR600 cases with the stock intake and exhaust, Cooler Master hyper 212 black edition CPU coolers, Nvidia RTX 2070 Super black GPUs, and i7 10700 CPUs. Currently, I'm idling at around 55c on the GPU, and the CPU idles at anywhere from 35 to 40c. We have about a 10 degree difference in both the CPU and GPU, which had me a little concerned.
Playing games on 1440p like Battlefront 2, I've had the GPU go up to 77c and the CPU at about 65c. I've looked around but couldn't quite find a consensus on if this was normal since it seems like the only difference we have is he has two intake fans instead of just one which he took out of his old case. I'm skeptical that the PSU may be having issues due to some liquid that was spilled into it while I used it into my other build. Other than that, I'm at a loss but I want to make sure I'm not overreacting. Any help would be greatly appreciated.
https://linustechtips.com/topic/1238659-concerning-temps/
A GPU temp of 77C in a AAA game at 1440p is on the high side, but it's certainly nothing to be worried about. As for your CPU, 65C is a great temperature under an intensive load. As far as I can tell, you have nothing to worry about cooling-wise.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1238659-concerning-temps/#findComment-13957540
Temps are fine, idle and underload, either way idle temps do not matter, load temps do.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1238659-concerning-temps/#findComment-13957541
I don't think you provided any direct comparisons between the 2 systems, but I can say with confidence that none of the numbers you've provided are concerning whatsoever.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1238659-concerning-temps/#findComment-13957542
https://linustechtips.com/topic/1238659-concerning-temps/#findComment-13957553
That’s relieving to know the temps are all okay. I was mostly curious because the only difference between our two computers at the moment is he has his PC in a larger room and there’s an additional DC intake fan in his case. I wasn’t sure if those two factors alone and maybe ambient temperature were enough to cause a noticeable difference in GPU/CPU temperatures.
https://linustechtips.com/topic/1238659-concerning-temps/#findComment-13957567
An ambient temperature difference and an extra intake fan can account for his cooler temps, you have nothing to worry about.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1238659-concerning-temps/#findComment-13957596
