2 minutes ago, Patrik_ said:
Hello, I trying to mount Zalman CNPS4X on my lga1155 and lga 1150 board and there is no way it fits... I have right arm bits everything and it is always 1mm short.
I tried every rotation possible.
Are you sure you're using the Intel hardware?
https://www.zalman.com/EN/Product/ProductDetail.do?pageIndex=1&pageSize=10&pageUnit=12&productSeq=1011&searchCategory1=4&searchCategory2=48&searchCategory3=-99&searchKey=&searchWord=
Press Download > Download to download the manual and check if you are using the right hardware and doing all the actions in the right order.
The Intel and AMD clips look quite similar:
You also have to use a couple specific mounting holes and such too, so be sure to read the manual carefully.
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956375
I believe he's talking about the backplate. You can see the mounting points on the right aren't lining up.
@Patrik_ Is the backplate bent at all? You might find bending it out a bit will space out the mounting points enough to fit into the board properly.
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956382
Yes Im pretty sure, Problem is not with clips problem is with whole cooler backplate not going in. I have manual infront of me.
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956386
I actually have 2 same backplates because I building 2 PCs so Its not deffective but maybe this whole is one defective badge idk. I can force and screw it in but that nut witch is under board will just press on the board and probably break it
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956398
Im buying different cooler because whole mechanism was the biggest pain in my mounting history even that GC gelid cooler witch forced me to take out whole board out of case was in comparision saint.
Edit: I checked everything like 1000 times and everything is according to manual
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956401
Yeah, I wouldn't be comfortable forcing it to fit.
Only thing we can really suggest it contacting Zalman or the retailer you purchased it from and requesting a refund.
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956403
Its easy I will just return to retailer and they can do whatevery they want with I found this one witch is second cheapest one and mounting looks soooo good and easy. https://www.youtube.com/watch?v=m60H4HR7-HE
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956405
this really angered me because I lost so much time trying to fix it and I scratched both boards littlebit.
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956409
A single mm short means something just has to be bent into shape a tiny bit. Just flex the plate a little, it's not like they shaved 1mm off the middle by accident
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956413
nothing that backplate is metal so there isnt any flex
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956420
Metal can bend.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956423
8 minutes ago, Patrik_ said:
Let me refraze that there is like 0,2 out of 100. Didnt work.
from the pictures you shared, it just looks like you need to bend it more, not 0,2 degrees.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1238518-cooler-doesnt-fit/#findComment-13956453
