Good day all,
For a while i've been using an Aten USB3.0 4port switch so i can switch my peripherals between my work laptop and gaming pc.
This worked just fine, until recently. As for streaming purposes i purchased a streamcam (with an usb c to usb A converter).
Now i have connected the following:
Streamdeck XL
GoXLR Mini
Corsair K57 + Ironclaw on slipstream dongle (2:1)
HyperX Quadcast (but only for power, as it won't power from other sources?)
Logitech Streamcam
The issue i'm running into right now, seems to be bandwidth related.
Logitech software keeps saying i need to connect it to an usb 3.0 port.
Keyboard keeps missing some key's when typing fast.
When i turn on the streamcam via logitech software, i will hear a 'plop' (ground breaker) comming thru the GoXLR. (this only happens on my game pc, not the work laptop, which is an issue anyway as it has only 2.0 ports and as a result can't use more than 360p on the cam)
So the question is. Does someone know how to calculate the bandwidth i am currently using, or maybe a tool to measure it to see if i'm really hitting a bandwidth limit and not a power limit (as i'm not powering the switch so the go xlr actually turns off).
Let me know!
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1238424-usb-3-switch-issues/
Probably just too many devices on a single USB line. Each device needs to communicate with your computer separately. One device, the camera, needs most of that bandwidth, and it can't get it because the computer is switching between all the attached devices. You probably aren't hitting a bandwidth limit, you're hitting a switching limit. Not to mention it seems like you're also low on power given the GoXLR turns off when everything is being used.
I'd suggest powering the hub and connecting the camera directly to a USB 3 port on your computer so it doesn't have to share.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1238424-usb-3-switch-issues/#findComment-13955810
No no no, the GoXLR doesn't turn off when everything is powered. What i ment is that when i turn off the computer, and thus the power to the usb bus, the GoXLR powers off, as it doesn't have an off switch and i don't want it on when the computer's off.
Yeah and there in lays the problem. If i do that, i won't be able to use it for Team calls etc. for work. As popping up the laptop screen on a desk saturated with 3 27" screens i'm rather space limited, so the laptop is under the desk in a docking station.
How do i figure out if that is the case and not something else? (i have absolutely no experience troubleshooting USB related issues)
https://linustechtips.com/topic/1238424-usb-3-switch-issues/#findComment-13955829
