High idle temps?
Go to solution Solved by Lipe123,
It's a 7nm thing, the silicon can't transfer all the concentrated heat in such a small space to the top of the heatspreader super fast/quick.
I have a custom loop and similar temps, idle at 44-50C and full load in the 70's.
Hi guys, now I know idle temps don't really matter, however, surely mine are a little high? I am running a Ryzen 5 3600 at stock speeds cooled by a Kraken x63 and my temperatures bounce between around 45 and 55 degrees at idle. The ambient is probably around 20 degrees and I only have CAM open while testing. Load temps seem fine at around 70 in prime 95, I'm just curious as to whats causing this. Thanks.
https://linustechtips.com/topic/1238251-high-idle-temps/
40-55 idle is normal operation from what I've experienced/read. Perhaps look up 1usmus ryzen power plan and see if that changes anything (should give a small improvement to performance too)
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1238251-high-idle-temps/#findComment-13954507
13 minutes ago, TomH said:
snip
Depends on what's running in the background, there is usually loads of programmes that are actually on in the background, and with slower fan profiles that usually makes idles a bit higher, if you don't mind the noise you can set the fans and pump to 100% but idk if it's worth it. What are heavy load temps like?
Yours faithfully
https://linustechtips.com/topic/1238251-high-idle-temps/#findComment-13954525
