Compatible Interface for Behringer C2
Go to solution Solved by The Flying Sloth,
49 minutes ago, ColdPixel said:
Total noob with microphones.  Buying my first non-USB/3.5mm microphone setup.  I want to use it to improve my conference calls (Zoom, Webex, etc.).  Sounds like the Behringer C2 is a good option.  I have read The Flying Sloth's guide, and he recommends the Behringer UM2 or UMC202HD.  Since the C2 is a pair of microphones, I am thinking that means I need the UMC202HD - which seems to have two XLR inputs on it - as compared to the UM2 which has only one.  Is that correct, or am I misunderstanding something?
Thanks!
~Nick
UMC202HD is a much better interface than the UM2 or UMC22, I use the C2 as a daily driver and only use one at a time but if you did want to use both you could with the UMC202HD.
Thanks!
~Nick
https://linustechtips.com/topic/1237493-compatible-interface-for-behringer-c2/
Thanks!
~Nick
Correct. You need the UMC202HD. But only if you need 2 mics. So I guess the Um2
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
Thanks!
~Nick
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
Thank you both!  I will get the C2 and UMC202HD then.
For my own understanding, is there any benefit to using both C2 mics at once for video conferencing?
Now the tricky part is finding anyone with either of these in stock.  Judging from Amazon data, seems like COVID has led to a months long stock shortage.
No,
As for stores, I usually purchase from Thomann
@rice guru
