When I add an effect to a clip and select the Intensity of the Effect it applies the effect as it should to the clip. However when I want to use Keyframes and doesnt work anymore. So for example I add a Keyframe and put the Intensity of the Effect to 0% and a couple of frames later I add another keyframe and put the intensity of the effect to 25%. However the effects intensity will still be 0% all the time eventhough it should be 25% at the selected point. I checked if I had other unwanted keyframes which was not the case. This happens with all the clips I have and I tried multiple different effects and its always the same. Never had this problem before.
https://linustechtips.com/topic/1237114-premiere-pro-keyframed-effects-not-working/
