So I built a pc using used parts (again). Sorry @TofuHaroto for rgb.
Specs
psu: Cooler Master Gm Storm 750w (30€)
Cpu: ryzen 3 1300x (30€)
SSD: Samsung OEM 256gig sata 3 m.2 ssd (23€)
HDD: 1tg WD blue 5400rpm (15€)
Gpu: Msi gtx 970 gaming 4g (30€)
Mothebroard: Gigabtye b450 S2H (25€)
Ram: 2x4gb 2666mhz cl 16 g.skill hyper x fury. (25€)
Case: Cooler Master MasterBox pro 5 (10€ from a friend)
Psu: Got this from facebook marketplace. were happy about it. (was a tier B psu, now tier C :( ) but still 750w psu and this system pulls around 300-325w power when 100% stressing the whole system.
Cables were decent looking not ketchup and mustard. Non modular which sucked since i did not even use 50% of the cables. I was happy about the cable management what i did thought. (only few cables hanging)
Cpu: ryzen 3 1300x. Was a decent deal (30€) did some overcloking. got 3.9ghz at 1.325V. Decent oc in my opinion. It is cooled by my 3700x' stock cooler (wraith prism rgb). When using silent cure i get around 70c on full 100% A'VX stress test. When using normal preset i get around 65c. when agressive around 58c.
SSD: Samsung 256gig sata 3 m.2 ssd form random prebuild. Not ideal for windows since it is dramless, but much better than the harddrive.
HDD: Well it is a normal HDD nothing special.
GPU: The seller was nice and changed the thermalpaste before shipping it to me. Overcloked it by +50 on core and +1000 on memory stable. Runs at 70c when cure is not agressive, runst at 65c when agressive.
heaven benchamrk score: 1977
Mobo: Decent deal. nothing fancy but can run ryzen 3700x at stock. mayby even runs ryzen 4700 at stock (if it gets a beta bios for it)
Ram: again nothing facny. runs without any issues form memtest. Won't oc it isnce Zen's imc is pretty crap after all.
the case was a nice deal. 10€ for a case with class sidepanel. pretty nice. did come even with 1 fan at the rear. will not add fans the front sicne thermals arent an issue.
Edit: cost me only 190€ lol.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1236965-ryzen-1300x-machine/
1 minute ago, SupaKomputa said:
That's a sata3 disk, not nvme.
good catch i had a brainfart typing that lol
https://linustechtips.com/topic/1236965-ryzen-1300x-machine/#findComment-13944378
3 minutes ago, jaslion said:
Is it the meshed masterbox? If not this is truly a cursed rgb box :p.
not meshed sadly. has decent airflow from the front
https://linustechtips.com/topic/1236965-ryzen-1300x-machine/#findComment-13944383
