What motherboard do you have?
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1236378-i-need-help/#findComment-13939753
1 minute ago, WorkedPrawn6766 said:
asrock a320m hdv
it is worth updating. I would recommend B550 motherboards for budget
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1236378-i-need-help/#findComment-13939771
asrock a320m hdv
I don’t know how good that specific board is, but I would not use an a320 board with a 2700x. What is your budget for cpu and motherboard and what country are you located in?
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1236378-i-need-help/#findComment-13939775
Just now, WorkedPrawn6766 said:
a320m hdv
I wouldn't pair this with a 6 or an 8 core. Let alone a 2700x.
Sadly this board will most likely if not will definitely throttle both..
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1236378-i-need-help/#findComment-13939776
okay cool thx for the help
sorry B550 didn't see the budget.
I recommend Pro4 from ASRock or DS3H from GIGABYTE.
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1236378-i-need-help/#findComment-13939786
A320 can probably handle a stock 3600.
Update bios if it lets you, install 3600, point a fan on the vrm
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1236378-i-need-help/#findComment-13939797
