Help with Deleting A Line In Python
Go to solution Solved by Hans Christian | Teri,
What exactly is it that you want to do? Print the file and select lines to delete? Just delete line 2 to 4? Either way your problem can probably be solved by loading the lines of text into an array, removing the lines you don't want to keep, and overwriting the file with what lines are left in the array.
I have been looking thourgh the internet for close to an hour and a half, and have yet to find some that A) Works, B) Is Simple to understand so that I can replicate it, and C) Is actually what I'm looking for. All I want to do is just simply remove a line. I'm not looking to remove a specific line with specific text, just a line in a .txt file. Ex:
(The Numbers Just represent the line #, not written to file)
1: A
2: C
3: D
4: T
5: X
delete line 2-4
1: A
2: X
The lines won't always have the same text, so I can't just delete that. I'm not going the share the real code as it is all just opening the document, printing it, and closing it. Reply if you need anymore information.
https://linustechtips.com/topic/1236333-help-with-deleting-a-line-in-python/
That worked, thank you. I glad that I could find a good source of information.
32 minutes ago, TheSnowman37 said:
-snip-
This might help you.
https://stackoverflow.com/questions/4710067/using-python-for-deleting-a-specific-line-in-a-file
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
