Hello everybody.
I have a old pc like 4 years old and i want to upgrade it (it is a prebuild).
So i went onto the internet and selected some parts that i wanted but am affraid they might not be compatible or am bottle necking some thing.
If someone wants to check for me and correct me if neccesary that would be very nice.
The Parts:
https://www.alternate.nl/EVGA/GeForce-RTX-2060-KO-GAMING-grafische-kaart/html/product/1608032?
https://www.alternate.nl/AMD/Ryzen-7-3800XT-socket-AM4-processor/html/product/1647382?
https://www.alternate.nl/GIGABYTE/B450M-DS3H-socket-AM4-moederbord/html/product/1465739?
https://www.alternate.nl/Corsair/16-GB-DDR4-3200-Kit-werkgeheugen/html/product/1220684?
https://www.alternate.nl/be-quiet/System-Power-9-500W-voeding/html/product/1418651?
https://www.alternate.nl/Samsung/860-EVO-1-TB-SSD/html/product/1405526?
https://www.alternate.nl/Cooler-Master/Hyper-H412R-cpu-koeler/html/product/1396160?
The reason there is no case or a hhd inculed is because am gonna use the case and hhd of my current pc and ripp all the other stuff out.
Thx for reading and hopefully i dint make some stupid mistakes.
P.S sorry fore bad english its my second language
https://linustechtips.com/topic/1236227-pc-parts/
Just build a new PC the case isn't worth building in unless it's meant for upgrades you can keep the HDD tho, since you have an HDD already go for a 500GB boot drive saves some money
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1236227-pc-parts/#findComment-13938183
The Parts:
Some parts are good, some a bit odd.
It would help in know what you will do with the system, what the budget is, etc. Could you please fill out this:
Quote
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
Personally I would get a different board, get a new case, choose a different SSD, get a different PSU and possible do something else with the CPU/GPU combo (and possibly ditch the cooler, if changing the CPU too).
For example, for a gaming system you'll probably want to spend less on the CPU, more on the GPU.
https://linustechtips.com/topic/1236227-pc-parts/#findComment-13938194
My budget is around 1000-1100 euros
I live in the netherlands
Mostly some basic games like tf2 and mc but i want to play cod warzone and battlefield on it in the future.
Some other stuff 60 fps is fine extra is always fun but it isnt necesary it has to be good for like 4 years and am upgrading from a gtx 1050 with a intel i5 and 8 g ram ddr 3 like 2300 mgh i think
https://linustechtips.com/topic/1236227-pc-parts/#findComment-13938219
You can go for something like this too:
A Ryzen 5 3600 + RTX 2060 Super combo just makes more sense for a gaming purposes, as opposed to a 3800XT + 2060 setup.
Other than that, I added a case, adjusted the PSU to one better suited for the system, same for the motherboard, different SSD (that's better in terms of speed too; the 860 EVO is kind of overpriced here in the Netherlands) and the cooler in this build is a great deal quieter.
If you're 'just' targeting 1080p60fps, you could certainly also go for something like a GTX 1660 Super or even 1650 Super, which would do 120 or 90 fps respectively.
https://linustechtips.com/topic/1236227-pc-parts/#findComment-13938286
