High refresh rate monitor for minimal gaming?
Is there any point in terms of general productivity of getting a high refresh rate monitor?
I game but I don't game a lot and I am looking for upgrades to my 1080p 16:9 60hz 24" Samsung
to a 1440p ultra wide I just don't know what sort of benifits there are to counteract the additional
cost of 120hz+.
Any advice welcome! :)
CPU: i7 6700
GPU: GTX 1060 6GB
RAM: 16GB DDR4 2133 MHZ
Storage: 2TB Crucial SATA SSD + 2TB WD BLUE
If you really enjoy the smoothness of high refresh rate, sure why not.
Aside from that There isn't really much of a point
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
cost of 120hz+.
Most cheap monitors will have worse color when at high refresh rate mode, not notably but a little bit. Sharpness/quality image of tiny things will be slightly less "nicer"
When I'm not gaming or doing something that doesn't require 120Hz I don't use high refresh rate
But the color problem can be solved by tweaking the colors while in high refresh rate mode so the they will not feel washed out
Ignoring these problems it's awesome when you play games
