I just switched my aging AIO with a 212 EVO cooler.  I want to re-purpose the fans from the AIO as case fans for more air flow.  Currently, I have a 140MM in the rear for exhaust and 2 140mm fans in the front of the case as intake.I want to add the 2 fans from the AIO in the top of my case but I dont know if they should be intake or exhaust.  The fan on my cooler is also in a push setup.  For reference, my case is a Thermaltake H200 TG RGB Snow Edition (See link).
https://www.amazon.com/Thermaltake-Tempered-Glass-Pre-Installed-CA-1M3-00M6WN-03/dp/B07X57R96B/ref=sr_1_1?crid=SU8A7O8G82R0&dchild=1&keywords=thermaltake+h200+tg+rgb%2C+snow&qid=1597511740&sprefix=Thernaltake+h200%2Caps%2C185&sr=8-1
Any help would be appreciated!
Here's a photo of the current setup.  Ignore the lettering on the graphics card, I was proud of my card when i got it lol.
https://linustechtips.com/topic/1234750-fan-direction-question/
clean the dust bro
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13925963
If anything, I would put one fan in to top rear as exhaust, and thats it. That way you get a nice column of air from the intake fan directly at the heatsinks fan, then the heated air will go out the rear and rear top fans. That will be plenty enough airflow.
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13925964
1 minute ago, sub68 said:
clean the dust bro
Its not very dust, looks mostly fine to me.
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13925968
the front fans
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13925972
Never considered that.  I'll give it a try!
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13925985
2 minutes ago, HesCalledTheStig said:
Thank you captain obvious.  I will be cleaning the dust while I take care of other maintenance including adding the fans.  If you dont have an answer for me, go away troll.  Thanks!
well having a top exhaust like @LIGISTX said
also nice big hero six figure
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13925987
The ideal setup would be with a balanced airflow between intake and exhaust (actually slightly unbalanced favoring intake, to prevent dust from finding its way through the case openings). Usually, you'll want to have more intake fans than exhaust. At the same rpm, an intake moves less air due to the resistance of dust filters and radiators (and case obstruction, if present). That being said, either have more intakes or slow down the exhaust ones.
In my case I have 6 fans, 3 intakes and 3 exhaust. The exhaust being locked @5v (they're not PWM) while the intake ones ramp up as temperatures rise.
What I would do, is buy some dust filters such these (if the case doesn't have any top ones), put both fans as intake and run them at it's lowest (either with a fan controller or PWM).
Another option would be what @LIGISTX said, just make sure to tune the rpm (of either the exhaust or the intake) to get a balanced airflow.
If you don't care at all about dust buildup, run it as you please. Exhaust fans are marginally more effective than intake at cooling.
MOTHERBOARD: ASRock H97 Pro4 CPU: Intel Core i5-4460 @3.30 Ghz Intel Xeon E3-1271v3 @4.00 Ghz RAM: 32Gb (4x8Gb) Kingstone HyperX Fury DDR3@1600 Mhz (9-9-9-27)
GPU: MSI 390 8Gb Gaming Edition PSU: XFX TS 650w Bronze Enermax Revolution D.F. 650w 80+ Gold MOUSE: Logitech G502 Proteus Spectrum KEYBOARD: Monokey Standard Suave Blue
STORAGE: SSD Samsung EVO 850 250Gb // HDD WD Green 1Tb // HDD WD Blue 4Tb // HDD WD Blue 160Gb CASE: Fractal Design Define R5 Windowed OS: Windows 11 Pro x64 Bit
MONITORS: Samsung CFG7 C24FG7xFQ @144hz // Samsung SyncMaster TA350 LT23A350 @60hz Samsung Odyssey G7 COOLER: Noctua NH-D15
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13926017
The fans I have are PWM so I like the idea of running them both as intake. The case has a magnetic dust filter on the top.  I wish it had filtration in the front as that's where my dust issue stems from.  I live in a very old house that seems to produce 10x the amount of any other place Ive lived, haha.
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13926055
That explains the dust. I haven't cleaned my rig in a full year and I'm not even close to that amount. Always have dust filters on intakes, if possible.
How's the exaust fan running now? You might have to ramp it up if going 4 intake.
BTW, I've edited the link. You might want to try in those filters fit in the front. They're not pretty tho
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13926077
The rear exhaust fan is also running off a 4 pin PWM header on the motherboard.  Should I install a fan controller to keep it running full throttle with the new intake fans installed?
As for the filters you linked, they would actually be perfect.  I'd never even see them in my setup.  The only issue is, I'd have to disassemble the case everytime I wanted to clean them.  Unless I put them on the rear of my fans inside the case.  In that case, they would definitely be an eyesore.
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13926091
On what header is the fan connected? Check in the bios if there's a option to control the single headers
You could try to fit them between the fans and the rad, don't know if this would actually make it any easier. At this point I'm not even sure if they'll do their job.
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13926116
6 minutes ago, HesCalledTheStig said:
Possibly a dumb question but what if I was to run the fan more towards the front as an intake and the one towards the rear as an exhaust?
I don't know if the fans will interfere with each other honestly. You can test it
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13926475
The case isn't that large so I don't think you need to put two more intake fans on the top.  Your front intake fans are pretty much blowing directly into the cooler fan so the cooler is getting direct fresh air from the front intake.  Adding a top intake in the front half of the case basically means you have two fans blowing into each other and possibly redirecting the airflow before it reaches the cooler.  If anything, a low rpm setting on a exhaust fan in the top rear like @LIGISTX mentioned before would be all you need. Put a filter on the front intakes then try to create a slight positive pressure in the case so that the air is trying to find any way out. Negative air pressure would mean the case is trying to suck air in through any hole, gap, or crevice without a dust filter which would mean dust everywhere.
https://linustechtips.com/topic/1234750-fan-direction-question/#findComment-13926770
