Hi all,
im building a rig for my friend currently and I’m having an issue with the build in general and didn’t know if it was a MOBO issue or a gpu issue what have you.
specs:
ryzen 5 3600
b450 tomahawk max
RX 570 8gb
16gb DDR4 gskill 3200
rm750x
1tb SSD
120gb SSD( for boot)
problem I am having here is when everything is connected ( yes everything is connected properly tripled checked each time) it powers on for a quick second flashes 3 debug ( GPU, DRAM and BOOT) then shuts down. Now I’ve taken the GPU out and it worked fans spinning and what not ( didn’t visualize a post screen or anything cause I just wanted to see if it worked) so I am wondering is this a BIOS update thing for the MOBO or is the GPU faulty or needs something done to it?
honestly any suggestions would be great to hear
https://linustechtips.com/topic/1234578-b450-tomahawk-max-issue/
that psu is one of the bets right now.
haby you tierd other poci e slots? sometimes taht happens when either the gpu is fualty, isnät plugged in the slot 100% or the slot is faulty
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
