2 minutes ago, Kijlok25 said:
sooo I guess a new SSD. After plugging it in I get a disk error. Help?
need to add a volume
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1234436-issue/#findComment-13922347
Just now, Kijlok25 said:
Wdym?
when a drive is new it doesn't have a file system
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234436-issue/#findComment-13922378
You mean I need to insert a new media key?
no if you have windows up add a volume to the drive like fat 32
but if its a boot drive create windows usb and install windows
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234436-issue/#findComment-13922392
3 minutes ago, Kijlok25 said:
How do I do that?
I added things to the post
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234436-issue/#findComment-13922403
Pc's
Towers:
Laptops:
#Muricaparrotgang
https://linustechtips.com/topic/1234436-issue/#findComment-13922411
Hey guys. So today I bought a SSD for my computer. after installing it and restarting my PC I got a Disk ERROR and it asked me to enter a media file or boot from another device(somethin like that).
After trying to plug in my USB woth the windows inataller on it. I installed a fresh windows. Now the new SSD is the windows installation Drive. BUT for some reason I don't see my 1TB SSD that has been connected to my PC for over 2 years and worked completely fine. Now. Its not showing up in BIOS. When I go to drive manager(i think thats how its called) i only see my new SSD. It is connected correctly I DIDN'T TOUCH ANYTHING. JUST INSTALLED THE NEW SSD M.2 and thats it.
I have a ab350gaming MotherBoard
And litreally IDK what to do. Please help guys. Ill provide any information needed.
Thanks.
https://linustechtips.com/topic/1234436-issue/#findComment-13922901
So you just installed an m.2 ssd and now the ssd you already have in there (connected to a sata port) doesnt work? If so, move it to a different sata port on the motherboard. Adding an m.2 ssd makes the motherboard disable certain ports (see below) so you have to move the ssd to one of the ports that is still active.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1234436-issue/#findComment-13922913
Just now, ShrimpBrime said:
Check the cable power and data cable. Be sure they are plugged in all the way. Can even try a new data cable, the can go bad
If this doesn't work, confirm the drive is bad by installing it in another
Let's say it will work on another PC. What do I do now?
https://linustechtips.com/topic/1234436-issue/#findComment-13922915
Didn't help. Connected it to another and I still dont see it.
https://linustechtips.com/topic/1234436-issue/#findComment-13922946
My new SSD is a pcle gen 3 256GB Transcend 220S
https://linustechtips.com/topic/1234436-issue/#findComment-13922955
If you take out the new m.2 ssd, does the old ssd work?
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1234436-issue/#findComment-13922970
Let me check. Ill need to reinstall windows again it can take 10minutes if u will still be able to troubleshoot with me
no need to reinstall windows, just see if it shows up in the bios now
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1234436-issue/#findComment-13922986
1 minute ago, Kijlok25 said:
Nothing is there. No boot option
Then something happened to your ssd. Make sure the power and sata cables are properly secured on both ends. If they are, check it in another system if possible. If it doesnt show in the other system, it is likely broken. There is a possibility it is something else, but I dont know what it could be.
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1234436-issue/#findComment-13922999
Its working without the new SSD. But when I plug it in. bios doesn't see the SSD(old one). Something is interpreting
https://linustechtips.com/topic/1234436-issue/#findComment-13923023
